Have been testing and researching many options for vpn, and running into issues with stability, mostly with it disconnecting every several minutes (Routing all phone traffic through IKEv2).
I cannot find any information on custom SSL VPN's.
Does anyone recommend a VPN Solution, one that is software based (ISO or VM), and can do per-app vpn (with low cost, one-time or opensource)? or even to route all traffic. (Always-on)
Thanks.
