OK, I admit that I am in the early stages of researcing this issue. However, after upgrading to 9.98 I'm experencing a consistant issue where a previously imaged machine, with saved autorun data, will NOT execute my First Run Script when being re-imaged re-imaged. Checking the box labled : "Store imaging settings as Autorun data in the JSS" completely resolves the issue and the First Run script will execute as expected.
I am running JSS 9.98, Casper Imaging (tested both 9.93 and 9.98) verified with 10.11.6 and 10.12.4 NBIs.
Any thoughts before I start tearing into things?
