Mac temporarily Frozen when selecting nbi after NetSUS 4.1.0 upgrade
  • November 22, 2016
  • 4 replies
  • 44 views
After upgrading to v4.1.0, I can see the nbi after option booting but as soon as I select it, the mac sits in a frozen state for about 20 seconds before it decides to boot to the already installed OS on the internal hard drive. Any clues on what the problem could be? I even tried downgrading back to v3 and the issue appears to be here to stay. There were no issues before the upgrade to v4.1.0. Has anyone else experienced this?
Thanks
  • November 24, 2016
DLewtheCEO
it maybe a forked version of the OS that is causing the issue. Can you give a bit more info on the nbi and hardware you are trying to netboot
  • May 13, 2017
A bit late to this party, but YES! On a Centos 7 VM running NetSUS 4.1.0, the target Mac can see the NBI hosted within the startup manager and is able to select it, only to have the target mac then delay for ~20 seconds and then boot from the target Mac's primary hard drive. I thought my next step is to verify that the required ports per https://support.apple.com/en-us/HT203437 are open: UDP 67, 68, 69, TCP 80, 548, and TCP/UDP 111, 600-1023, and 2049. (Yes, we could go with either NFS or HTTP; not sure if 548 is still pertinent; seems like it should be 139 and perhaps 445 as well).
Interesting to see that the issue may be NetSUS 4.1.0. Curious if you found an answer to your issue? BSDPy, perhaps?
  • May 18, 2017
With a suggestion from Matt Woodruff, we renamed our NBI from 10.12.5NetBoot.nbi to 10125NetBoot.nbi (removing the periods within the filename). With a reboot to the server, it is now NetBooting. Still a bit slow, although that is another issue.
  • March 27, 2018
I didn't even notice there were responses to this. I'm trying to think back but I believe the issue ended up being that the IPTables were changing to a more restrictive state. I had to address why it was changing and adjust the config appropriately. Thanks for chiming in.
