DB connection issues after server reboot
  • February 9, 2018
  • 12 views
Migrated to another server as per this documentation
http://docs.jamf.com/10.1.0/jamf-pro/install-guide-linux/Migrating_to_Another_Server.html
Even though the database user password is correct in the configuration file /usr/local/jss/tomcat/webapps/ROOT/WEB-INF/xml/DataBase.xml
on reboot the database authentication fails.
On accessing the site, I am greeted with a database connection error.
After selecting “Edit Connection”, I am able to proceed accepting the database password which is already pre-filled in the dialog.
It then goes through an initialisation process, after which it is ready for use
1 reply
  • February 9, 2018
Permissions or file syntax errors are what come to mind
