Jamf Trust UEM Connect permissions
  • March 21, 2024
  • 151 views
0ne-nine9
Hey guys. New to JamfPro line-up but I've gotten the hang of it pretty well.
During the integration between Jamf Trust (Security Cloud / Wandera / RADAR / Please setup a naming convention), and Jamf Pro as the UEM, you have the option to either authenticate with Basic Authentication (Username, Password), or with OAuth, utilizing an API client in Jamf Pro with the appropriate permissions.
The permissions are listed here, under the Requirements section. This Requirements section is the same for all versions of the Jamf Trust (Security Cloud, Security, Safe Internet, Wandera, RADAR, Please setup a naming convention) documentation, even the deprecated ones.
https://learn.jamf.com/en-US/bundle/jamf-security-cloud-setup-guide/page/UEM_JamfPro_Establishing_UEM_Connectivity.html#task-6779
  • A Jamf Pro API Role and Client with the required permissions. For more information about API Roles and Clients with Jamf Pro, see API Roles and Clients in the Jamf Pro Documentation.
    • For device sync (mandatory), the following permissions are required:
      • Read Mobile Devices
      • Read Smart Mobile Device Groups
      • Read Static Mobile Device Groups
      • Read Computers
      • Read Smart Computer Groups
      • Read Static Computer Groups
      • Create Static Computer Groups
    • To use risk level signaling, data policy signaling, or device threat signaling, the following permissions are also required:
      • Create Computer Extension Attributes
      • Delete Computer Extension Attributes
      • Read Mobile Device Extension Attributes
      • Delete Mobile Device Extension Attributes
      • Create Mobile Device Extension Attributes
      • Update Mobile Devices
      • Update Computers
      • Update Users
I have setup an API client in Jamf Pro with these exact permissions, however the UEM integration sync fails with the following error each time:
I've then tried to replace the OAuth credentials with Basic Authentication, using my Jamf Pro superadmin username and password, and the synchronisation works. This points to the documentation having less than the required amount of permissions for UEM to actually work with the API client.
Has anyone figured out what other permissions are required for the API client? I don't want to use my superadmin Basic Authentication credentials.
Best answer by Rick_Goody_Jamf
Hi @0ne-nine9
If you add the following roles to your api roles you should have success
  • Update Mobile Device Extension Attributes
  • Read Mobile Device Applications
  • Read Computer Extension Attributes
  • Update Computer Extension Attributes
  • Read Mac Applications
this is the full list based on my API Roles
  • Read Computers
  • Update Computers
  • Update User
Rick_Goody_Jamf
Hi @0ne-nine9
  • Read Computers
  • Update Computers
  • Update User
0ne-nine9
  • March 22, 2024
Hi @0ne-nine9
  • Read Computers
  • Update Computers
  • Update User
This worked perfectly Rick, thank you so much for the reply!
