Best practice for Self Service Upgrades?
  • February 12, 2018
  • 5 replies
  • 54 views
Whenever a new version of a browser comes out, I create and upload the pkg, and then upload it to the JSS and set it to Make available through Self service.
What is the best practice for killing and (removing if necessary) the existing sessions and editions of say Chrome and Firefox?
I've noticed after installing them, and then launching the browsers, they both seem to request a restart to update - which isn't ideal
Do you put in a pre-installs script to remove the older version? If so, does this work without removing all of their bookmarks and extensions?
Best answer by AVmcclint
Here's what I use to upgrade Firefox in self service. pkill makes sure the app is quit first. I also have it look for any copies of firefox that the user may have installed into their home folder- they like to do that.
#variable for storing the current users name
currentuser=`stat -f "%Su" /dev/console`
# kills the firefox process before updating
pkill firefox
# delete /Applications/Firefox.app and ~/Applications/Firefox.app
rm -Rf "/Applications/Firefox.app/"
if [ -e "/Users/$currentuser/Applications/Firefox.app/" ]
then
    rm -Rf "/Users/$currentuser/Applications/Firefox.app/"
else exit 0
AVmcclint
Forum|alt.badge.img+21
  • February 12, 2018
pkill firefox
then
else exit 0
AVmcclint
  • February 12, 2018
I do have to get more creative with Chrome because it's autoupdate is tougher to kill. There are threads about that somewhere here in JamfNation.
john_sherrod
  • February 13, 2018
Are you scheduling your updates for a certain time of day? Just curious how you handle that since killing Firefox while the user is using it could be disruptive.
AVmcclint
  • February 13, 2018
I put it in self service so users do it at their convenience, but I also make it a Login item so there's no chance of it interrupting them and it automatically installs.
john_sherrod
  • February 13, 2018
That’s a really good idea. I need to implement that.
