Jamf Connect 3.4.0 not deploying or upgrading — still installs 2.45.1 despite new PKG upload
  • November 4, 2025
  • 7 replies
  • 892 views
Hi everyone,
I’m running into an issue trying to upgrade Jamf Connect across our environment and hoping someone from Jamf or the community has seen this before.
Until recently, I was able to update Jamf Connect using the dropdown under
Settings → Jamf Apps → Jamf Connect → Deployment and Update Settings.
That list used to automatically show each new version as Jamf released it (for example, 2.44 → 2.45).
Now the dropdown has stopped updating — it’s capped at 2.45.1, even though 3.4.0 has been released publicly for several weeks.
I’ve tried to manually handle the upgrade:
• Downloaded JamfConnectLogin.pkg (3.4.0) from account.jamf.com.
• Uploaded it into Jamf Pro (Cloud Distribution Point).
• Created a policy to deploy it to test devices and tied it to our existing PreStage.
• Policy runs successfully, reports “completed,” but the actual version on the Mac remains 2.45.1 — both in Get Info and when checking the bundle version via Terminal.
• I’ve confirmed the correct PKG is being used, deleted the old 2.45.1 from the repo, flushed logs, etc.
We’re on Jamf Cloud 11.20.1, and all Jamf Connect auto-deploy settings have been set to “No” to avoid conflict with the outdated catalog version.
At this point, I’m wondering:
1. Has anyone else seen this behavior where Jamf Connect 3.x fails to install/upgrade and reverts to 2.45.1?
2. Is Jamf aware that the Jamf Apps catalog hasn’t been updated beyond 2.45.1 for some tenants?
3. Is there a documented process change for deploying Jamf Connect 3.x manually?
Everything used to work beautifully through the Jamf Apps auto-deploy flow, so this new process feels like a step backward.
Any insight, confirmation, or official Jamf comment would be hugely appreciated.
Thanks in advance,
Cesar D.
Jamf Cloud Tenant v11.20.1
mickgrant
  • November 4, 2025
Hey mate,
Looks like auto-update of jamf connect login via Jamf Pro app settings is only supported up to version 2.45.
https://learn.jamf.com/bundle/jamf-connect-documentation-current/page/Managing_Jamf_Connect_Login_Window_Updates.html
For versions after that its suggested to use manual policy deployment, or app installers.
hope this helps you
msandee
  • November 5, 2025
Jamf Connect beyond 2.45.1 is tied to Self Service+, as in it is part of the functionality of that. The jamf app catalog only goes to 2.45.1 intentionally because you should not be using jamf connect 3+ if you aren’t using Self Service+ yet. If you are using the login window functionality that is a separate app in jamf app installers, jamf connect login, and is current (3.5 in mine now). I am not official jamf, but that is my understanding.
AJPinto
  • November 5, 2025
Jamf Connect login and Jamf connect menu bar are two different applications.
The Menu Bar has been replaced by Self Service+ and if you are on Self Service + the menu bar can just be removed.
Updating Jamf Connect 3+ just updates the Login Window app as that is all it is for. There is an App Catalog item for this, but it’s separate from the one that was for Jamf Connect 2 due to lacking the Menu Bar component.
kcollins7
  • November 5, 2025
Will updating the Jamf Connect Login to 3.5 remove or break the Connect Menu Bar for 2.45.1 or will that functionality remain?
  • November 7, 2025
Found this thread after running into the same issue as the OP.  After installing 3.5.0 via PKG, the 2.43.0 menu bar app seems to be working fine still.  Obviously still test for yourself in your environment, but seems like it’ll probably be fine.
edimock
  • November 20, 2025
I’m having a similar issue…
I have no problem updating existing Macs from 2.45.x to 3.4.0. It works fine by just installing the new Jamf Connect Login and Self Service+ packages together in a policy. However, when I cloned our production prestage enrollment profile (which still installs 2.45.0) and just removed the old Jamf Connect and Launch Agent packages and replaced them with the new Jamf Connect Login, Launch Agent, and Self Service+ packages, these 3 apps do not install during enrollment. What am I doing wrong?
edimock
  • February 4, 2026
Sorry for hijacking the thread a bit, but I just figured I’d give a little update to my situation in the post above. I seem to have gotten it working again by re-adding Company Portal to the enrollment packages (we use Entra ID). I must have accidentally removed it after cloning the old profile. The newer (3.x) Jamf Connect packages seem to install as expected during enrollment now and I am taken to the Entra ID login screen, which is how it creates the user’s local account on the first login, instead of taking me to the native Mac login screen that I had been getting. Hope that helps anyone else that runs into this.
On another note, Jamf really seems to have made this about as confusing as possible with breaking it all up into different pieces with different version numbers...
Jamf Connect Login - 3.6.0
Jamf Connect/Self Service+ Menu Bar - 3.13.0
Self Service+ - 2.15.0
As far as updating these components, the “Jamf Connect Login” app is available now in the Jamf App Catalog (note: not to be mistaken with “Jamf Connect” which still appears in the catalog and tops out at version 2.45.1)
I currently have two instances of the app set up there. One is automatic and goes to a small pilot smart group and the other is manual deployment to the rest of the Macs, that I manually change the deployed version on once piloting confirms there are no issues. Unfortunately, Jamf doesn’t have Self Service+ in the app catalog, but perhaps that is because when it eventually fully replaces the classic Self Service, it will just keep itself up to date. But for now, it seems that you have to manually deploy updates. I update it with a package installer policy, and the SS+ package you download from your Jamf Account page will update both Self Service+ and the Menu Bar.
