Populate ARD fields from casper suite console to computers
  • January 23, 2014
  • 10 replies
  • 56 views
Hi...
we configured manually some informations in ARD fields 1 and 2 in our admin console in casper.
We want those information to be copied locally in the same fields on the specific computers... but those information does not seems to be copied onto computers... is there a way to do this ?
so... : Some informations in ARD fields 1 a 2 in casper ... to be copied into ARD fields 1 and 2 on computers...
Best answer by jmercier
same version... these fields are in auto run...
but the thing is my tech entered the info after imaging the computers... oups......
i found it....
those fields are in auto run... so i just need to set only auto run to set the fields and not to reimage the computers and thats it... pfffffff.
thanks to all...
  • January 23, 2014
I thought there was an MCX setting for previous versions of the JSS. However, to read the data the jamf binary is doing:
[code]defaults read /Library/Preferences/com.apple.RemoteDesktop.plist Text1[/code]
thus you could do create a script that does the following:
[code]sudo defaults write /Library/Preferences/com.apple.RemoteDesktop.plist Text1 "WINNING"[/code]
  • January 23, 2014
hi....
that could do... but que thing is... in casper there is a place we can put in manually info 1 through info 4... there must be a way to transfert that info into machines... otherwise... these fields are in casper for nothing...
  • January 23, 2014
Yes, take a look at the help page for ARDAgent's kickstart-
sudo /System/Library/CoreServices/RemoteManagement/ARDAgent.app/Contents/Resources/kickstart -help
Specifically, the ones you're looking for are:
sudo /System/Library/CoreServices/RemoteManagement/ARDAgent.app/Contents/Resources/kickstart -set1 -1 "some text"
Change to -set2 -2, -set3 -3, etc to set up to the 4 fields.
  • January 23, 2014
Whoops, double post
  • January 23, 2014
Thanks mm2270....
but i wish it could be automatic from my info in casper instead of doing lines by lines, machine by machines... all my info ARD 1 is already in casper suite... so i wish a method that the casper console could send those info to the computers automatically
  • January 23, 2014
I would check out the setARDFields command in the Jamf binary - type "jamf help setARDFields" in terminal.
  • January 23, 2014
yeah... that works... BUT... i need to enter manually from terminal each field one by one since they are the inventory number of each computer...
is there a way to mix that command line... and to go grab my info that is aleardy written in casper database ?
  • January 23, 2014
What version of Casper are you running? I am on 8.73 and don't see a place in a machine's record where I can enter info for the ARD fields.
  • January 23, 2014
Same here. On 8.73 I don't see where those strings would show up in a computer record. In fact, in Casper Remote 8.73 I don't see where to add those to a record. Is this just something that happens during initial imaging or at some other stage? We don't use these fields, so I'm unclear where they even get set for a record in the database.
  • January 23, 2014
i found it....
thanks to all...
