First: This is not Apple approved. I know that, you know that, do it at your own risk. I do, this works fine. This is not a discussion about why or opinions :). Some of us have this need, this is one solution!
Step 1: Making a Mojave Image:
Have a good 10.14 master machine.
Mount master to another 10.14 machine (tested with 10.14.4, 10.14.5, and 10.13.3 - it does NOT work with 10.13.4, 10.13.5, or 10.13.6)
In Disk Utility Menu - View - Show all devices
Unmount APFS Volume under Container of drive you want to make image
File - New image - from Container (read-only). (NOTE: Unlike with High Sierra you DO NOT have to resize the partition first, the image is only as big as your used space)
Don't forget to scan image for restore! (from Menu - Images - Scan for restore)
STEP 2: IMAGING!
First Manually:
From Disk Utility on 10.14 machine/usb:
erase drive to APFS
Unmount Volume Under Container
Click on Container (not volume) and choose restore and Choose image made originally
My "IMAGER" https://tinyurl.com/APFSimager
(more info on my imager available in the High Sierra thread if you want specifics: https://www.jamf.com/jamf-nation/discussions/27001/high-sierra-imaging-how-to)
To use:
Download DMG and restore to USB Thumb drive. Thumb drive should be HFS+ and restore the HFS+ Partition on the Thumb drive with the Imager image above.
Place Firmware package in /Packages if you are imaging machines that are not at least on 10.13!
See my other thread for more info on pulling firmware: https://www.jamf.com/jamf-nation/discussions/27001/high-sierra-imaging-how-to
If you do not want to use Quickadd portion of imager simply delete the /Data folder.
Place quickadd.pkg in /Data if you want the machine to Enroll Via Quickadd after reboot.
Place APFS Container image in /Configurations (don’t forget to scan image for restore first)
Boot to USB and it will:
Erase internal drive 0 and make APFS, Restore Container, copy Firstboot files to run Quickadd, install firmware update if nescessary/included, and set startup disk and reboot.
