Cannot connect to iTunes Store
  • October 28, 2019
  • 6 replies
  • 63 views
I'm trying to push apps out to an iPad and they are all coming back with the error "Cannot connect to iTunes Store". I know I have licenses for all the apps. My DEP connection is current. All of my VPP Accounts connections are current. When I go into Global Management Settings there are exclamation points by GSX Connections (we never set this up), VPP Accounts, and Device Enrollment Program. I checked Apple's status site and everything related to those is green. My DEP says it synced a minute ago.
We're running Jamf version 10.13.0-t1559772983 on a Windows 2008 Server VM. (We need to migrate to a new VM before we can upgrade jamf any further).
Any thoughts?
Best answer by karenmartin
contacted Support... this is their response: 'Yesterday there were some widespread issues w/ the App store in general, My advice would be to cancel failed commands for that device, then push the app once more and try to install on a different network to rule out any network interference.'
I highly doubt network interference is the issue for us, b/c this is happening on about 1/2 dozen devices, across our school district. I will post any updates I get...
  • October 29, 2019
I'm having the same issue. None of my apps or Self Service is being installed on any of my new iPads that I'm deploying.
  • October 29, 2019
I noticed this issue yesterday afternoon, and it is still a problem this morning.
  • October 29, 2019
  • October 29, 2019
umm, Those Exclamation Marks are for information only..
Have you clicked on one of them??
  • October 29, 2019
Looks like it must have been a temporary Apple issue. All of the apps installed this morning at 7:30.
  • October 29, 2019
kerouak - Thank you, I had tried hovering but not clicking. <facepalm>
