failed to load launchAgent for user adobeinstall after Mac Prestage Imaging
  • September 29, 2017
  • 31 views
Since moving to 9.101, I have:
- Updated the NBI to have the latest Casper Imaging App
- Updated permissions for imaging (and actually turned off the requirement for logging in anyway).
On a couple of machines at image time, we have now had the message "failed to load launchAgent for user adobeinstall" so it's not running the required package installs after first boot.
This isn't happening on all machines - inconsistency is a pain to troubleshoot - but curious if anyone has ideas on where to start? Pushing El Cap (required App comparability issue) although NBI is Sierra.
Thanks
  • November 28, 2017
We've also just started seeing this as of a few days ago running 9.97.
Did you get anywhere with it in the end?
Many thanks
Dan
  • December 15, 2017
@dfarnworth_barc No, this is still a pain for us. Any luck on your side since your post?
