User Level Config Profile and DEP
  • February 16, 2018
  • 4 replies
  • 14 views
DBrowning
How do I get User Level config profiles to install on a DEP machine?
System Level config profiles install just fine. The only way i can get ULCP to install is running sudo jamf mdm -UserLevelMdm but when i do that, MDM "breaks" saying it requires DEP enrollment.
  • February 16, 2018
User Level Config profiles require your machine be bound to AD.
jmahlman
  • February 16, 2018
@rderewianko That or your user has to have an Apple ID signed into the App Store or iTunes I think.
  • February 16, 2018
I was having lots of issues with the ULCP's with DEP when we went to 10.13.2. Ultimately, in our prestage Jamf support asked us to uncheck "Allow MDM profile removal."
That seems to solve the problem. Are you seeing that the MDM profile is not approved in profiles after the enrollment?
We are bound also.
DBrowning
  • February 16, 2018
@LovelessinSEA We are also currently bound but will be moving away from that later this year. I currently have "Allow MDM Profile removal" checked. and I've made sure to go in and approve the MDM Profile. I will see what happens when I uncheck that box.
