I need help with a Basic script (please)
  • December 5, 2016
  • 7 replies
  • 36 views
I'm trying to run a script to check first if a file is already on the mac I want it to quit, and if the file is not on the mac to go ahead and install it.
At the moment I have a policy that copy the file to /tmp/CB/file.pkg than it gets installed.
( file.pkg gets installed into "/Applications/file.pkg")
But I want it to skip install if the file.pkg is already installed on the "/Applications/file.pkg"
I told you it was basic =)
this is what I have so far:
installer -pkg /tmp/CB/file.pkg -target /
Best answer by lkrasno
Many examples available online for "bash if" (and other conditional statements)
pkgDir="/tmp/CB/file.pkg"
if [ -d $pkgDir ]; then
    do this
    do that
  • December 5, 2016
    do this
    do that
  • December 5, 2016
that was fast! thank you.
one last question I want it to exit if the file is on the /tmp/CD/file.pkg and install if its not there....does the "exit" looks correct? (do I need a "exit 0" or "exit 1")?
thank you very much!
    exit
  • December 5, 2016
You're on the right track, and yes, ideally you'll want to use the appropriate exit code
  • December 5, 2016
got it thank you again!
donmontalvo
Forum|alt.badge.img+36
  • December 6, 2016
Would probably use -e unless that's a non-flat PKG.
  • December 7, 2016
A few comments:
  • Good idea to save resources and not do the transfer and install if not needed.
  • Instead of running the script again and again, just to find out the package is already there you could make a smart group that contains the devices that don't have the package installed, and run it only on these.
  • Non-zero exit codes usually indicate that an error occurred. It is useful to stick to that convention and don't use non-zero exit codes to signal something else.
  • A package in /Applications? Sounds weird to me.
Cheers,
Matthias
  • December 7, 2016
@mschroder thank you for your comments =)
yes you are right a package in Applications doesn't make sense =) I didn't explain it correctly, so the package gets download it to /tmp/CD/file.pkg than the scripts run the installer and what it actually happens the file.pkg installs the application into /Applications =)
I will also try your suggestion on using a smart group.
Thank you very much!
