I uploaded the S4b installer to the JSS, created a self service policy. Self Service says it installed correctly, but the logs show:
Installation failed. The installer reported: installer: Error -
I tried then pushing via C. Remote and it failed with the same error. I tried on one of my freshly imaged machines through self service and it did complete. So I went back through the logs and apparently it's failing consistently through SS.
Is it one of those apps I need to re-bundle with postimage script?
never mind, it is only compatible with 10.11 and higher.
@jwojda Gotta be careful, I ran into this same issue.
