sudden glut of "Policy Error Executing Maintenance on __" messages
  • March 1, 2010
  • 4 views
For reasons unknown, I am getting many (36 so far) error messages from my
JSS/Casper server, all with this subject line:
"Policy Error Executing Maintenance on (comp name)"
I rarely see messages like these so getting so many has me searching for
causes.
Has anyone seen something like this or have any suggestions on where to
look?
I haven't altered the policy "Maintenance" and I restarted my JSS/Casper
server a few hours ago. The seemed to stop the error messages. Then a
couple of hours later, they started again.
Here's the text from one of the error messages:
An error occurred executing the policy "Maintenance" on the computer
"GH-MB-A2".
Event log from the policy:
/usr/sbin/jamf is version 7.0 Executing Policy Maintenance... Mounting afp://10.1.0.103/CasperShare to /Volumes/CasperShare... Checking for current versions on JSS... +---------------------------------------------------------------------------------------------+ | Component | Installed Version | Current Version | Status | |---------------------------------------------------------------------------------------------| | /usr/sbin/jamf | 7.0 | 7.0 | OK | | /usr/sbin/jamfvnc | 4.00 | 4.00 | OK | +----------------------------------------------------------------------+-----------------------+ Everything is current. Running Script script-Enable ARD for ladmin.sh... Script Exit Code:0 Script Result: Starting... Activated Remote Management. Stopped ARD Agent. Stopped VNC Server. Stopped RFB Register MDNS ladmin: Set user remote control privileges. ladmin: Set user remote access. Restarted Menu Extra (System UI Server). Done.
Fixing Permissions... Flushing System Caches... Flushing User Caches... Verifying Disk mounted at '/' Result of disk verification: Started verify/repair volume (filesystem) on disk disk0s2 Macintosh HD
Performing live verification Checking Journaled HFS Plus volume Checking Extents Overflow file Checking Catalog file [31mIncorrect number of thread records[0m [31mIncorrect number of thread records[0m Checking multi-linked files Checking Catalog hierarchy Checking Extended Attributes file Checking volume bitmap Checking volume information The volume Macintosh HD needs to be repaired Error detected while verifying/repairing volume disk0s2 Macintosh HD:
Filesystem verify or repair failed (-9957)
Finished verify/repair volume (filesystem) on disk disk0s2 Macintosh HD Error detected while verifying/repairing volume disk0s2 Macintosh HD:
Unmounting file server... Displaying message to end user...
You can access the full details of this log at:
http://casper:9006/viewLog.html?log_id=1342758
or
https://casper:8443/viewLog.html?log_id=1342758
Computer Name: GH-MB-A2
IP Address: 10.1.7.19 ssh://ladmin@10.1.7.19
Asset Tag: T970
Realname: Local Admin
Username: ladmin
Department: Active
Room: GlenHills ML A
Email Address: T970
Model: MacBook (13-inch 2008)
Serial Number: W88256EN0P1
Total RAM: 2 GB
Processor: 2.4 GHz x2 (Intel Core 2 Duo i386)
Operating System: Mac OS X 10.5.8 (9L30)
You can access the full details of this computer at:
http://casper:9006/viewComputer.html?computer_id=582
or
https://casper:8443/viewComputer.html?computer_id=582
TIA,
Jeff Johnson
Technology Coordinator
Glendale-River Hills School District
Glendale, WI 53209
jeff.johnson at glendale.k12.wi.us
1 reply
  • March 1, 2010
The error I see right away is that the disk needs repaired, and the error
could be that it cannot repair a disk that it is booted from. I would try
booting that specific machine either from a Leopard Disc or a netboot server
and try repairing the disk. If that still throws an error, it looks like
you might need to run something like DiskWarrior on it.
Alan Benedict
Macintosh Technician
The Integer Group
O: 515-247-2738
C: 515-770-8234
http://www.integer.com
