Black screen with cursor on logout OS X 10.11.X
  • March 28, 2016
  • 6 replies
  • 51 views
Hello,
Clients of mine have been using 10.10.X for some time now and I have started upgrading many machines to OS X 10.11.4. One thing I've noticed is on logout the screen will display a black screen with just a cursor. The only thing I've found to resolve this issue is to force a reboot by holding down power. It might not happen every time someone logs out but it is frequent.
Has anyone else seen this issue?
Thanks in advance.
  • March 28, 2016
Yes, this is for personal systems and deployed systems. Ever since 10.113 and .4 its been really buggy.
Sometimes our users get fan speed increase from a cold boot into the OS and these are on maxed out 15-inch Retina MBP 2015.
And just last night had a handful of machines attempting to do a logout or a shutdown and the cursor + black screen issue occurred, tried to remote into it to give it a soft shutdown but had to force shutdown most.
  • March 28, 2016
Thanks @walt . At least I know it wasn't an image I created using AutoDMG. Ugh, I love Apple so much.
  • March 28, 2016
Quick question, do you happen to have a Policy Banner at all? We are using 10.10 currently and they tend to do this exact thing as well. I haven't seen it at all on 10.11 due to a small deployment group currently.
  • March 28, 2016
@jjones we don't and some of these weren't even enrolled in casper and theyre just out of the box set-ups relatively new systems from 2 months ago as well.
  • March 29, 2016
@jjones Login Window Banner under config profiles is being used.
  • March 29, 2016
I would look at what is being launched in /Library/LaunchAgents and also at any installed plugins.
We have a had a few issues on various machines this year since moving to 10.11 and they appeared to have been caused by the logged in user not having sufficient rights to kill/quit the process.
The two items that have definitely cause it were
- HD Audio plugin for Pro Tools 11 (only required if you have HD audio gear which we don't).
- Very old Sony camera drivers (which it turns out no one used anyway).
There are probably others as well.
