Hello everyone-
Casper Suite 7.2 will be shipping this week! Everybody should be getting an email with information by the end of the day on Wednesday. If you don't receive an email by then, or have pressing needs to upgrade sooner, please send an email to:
support at jamfsoftware.com
We'll be happy to get the information to you as soon as possible.
There are a number of new features and enhancements in version 7.2:
JSS Assistants:
Creating a Policy now gives you the option to walk through an assistant in the JSS. In addition to this assistant, there is also an LDAP Server assistant and a new assistant if you perform a clean install of the JSS.
Extension Attributes:
The JSS now allows you to add an unlimited number of items that you track for a computer record. You can create these as popup menus or text fields, or have them automatically populated by scripts. When building this feature, we focused on unification and extension of other Mac OS X products in the enterprise. We have included over 100 templates for Extension Attributes that allow you to gather custom information, including for the following third party products:
- CrashPlan - Atempo LiveBackup - Time Machine - ClamXav - Sophos - VirusBarrier - Virex - Forefront - VMWare - Deep Freeze - CheckPoint - PGP - WinMagic SecureDoc
Improvements to Managed Preferences:
In addition to support for uploading .manifest files and .plist files for creating new Managed Preferences, we have also tied in with the Manifest Destiny project started by our friends at AFP548 which is hosted at Google Code.
For a full list of new features, bug fixes and upgrade instructions, please reference the release notes in the disk image.
regards,
zach
This also fixes some other 10.6 related problems. Using JSS Setup Utility
7.2, you can now schedule replication to a distribution point running 10.6.
Anyone update yet?
