I had scoped a Config Profile (Login Window payload; change to name and password text fields) to a lab of iMacs. I noticed that the profile was working inconsistently, so I unscoped it and decided to tackle this with a command. However, I cannot make this change via command or in the GUI. If I go into the OS, this feature is greyed out in Users & Groups and cannot be changed. When I look at Profiles in System Preferences, this Config Profile is gone.
Is it sometimes necessary to wait an extended period of time before weirdness caused by a Config Profile is totally gone after the profile is unscoped?
