Road Map
  • March 29, 2016
  • 9 replies
  • 43 views
Hello Everyone!
My manager has asked for a high level (3-5 year) Road Map for Casper. I wanted to check with everyone and get suggestions on things that should be added to it. We have only been using Casper for about 6 months and is still in our test environment. We use it only for OSX and none of the MDM. So I figured admins that have been using it longer might be able to add some of their working knowledge to it. Thanks in advanced for any advice.
Best answer by dpertschi
I'm guessing you're manager wants to know how you plan to exploit the software for business gains in that time frame. How about this, in no particular order:
  • Introduce encryption deployment and management
  • Utilize the Restricted Software to block torrent apps or anything else non–business worthy
  • Introduce system and application settings management and enforcement with Configuration Profiles
  • Roll out the Self Service application in a wide range use cases
  • Install an additional web app in the DMZ to facilitate communications with Macs off network
  • Use, or know you can use the remote lock/wipe features for laptops that go missing
  • Enhanced patch management- as-is it's ok, we're all waiting on baited breath within 3-5 JAMF will be providing much requested enhancements
  • User driven self provisioning of new machines either via Self Service and or DEP
  • Greater awareness of the fleet in general through reporting (much lacking already, but highly useful anyway)
  • Integrate with a cloud service and provide software/patching to machines off network.
And, have zero-day (or nearly so) support for whatever the hell Apple throws at us to deal with.
  • March 29, 2016
The only real indication I'd look into for a Road Map would be under the Feature Requests tab here on JAMF Nation. Since you can see clearly what is planning to be added into the software but with the range you're looking at, it's hard to know where Casper will be in 5 years time, let alone iOS and OS X.
bpavlov
  • March 29, 2016
When you say road map are you talking about the product itself or about how you plan to use it in your environment to manage devices? If it's the latter then I would start by thinking of certain things that you would like to accomplish (or in reverse, look at all the problems in your environment that you wish you could change). It would essentially be a little bit of project planning.
  • March 29, 2016
I'll be the bad guy..
Getting a road map from a Jamf with it's sole purpose is to support Apple products and Apple it's self doesn't provided a road map is crazy...
And you providing a road map on how you are going to use Casper is just as nuts..as there is no visibility to what Apple is going to do..
Let not even talk about 3 to 5 years, let talk about tomorrow ... what happens if Apple locks down Mac OS X this June at WWDC? There is no amount of road map/planning that Jamf/you/Apple could do that is going to help anybody solve all the issues that this would cause..
C
PS You are going to wrong no matter what you do, just make stuff up... or try and teach your manager that he can't move it his speed or at a road map speed ... we all have to move at Apple speed, there is no other choice!
dpertschi
Forum|alt.badge.img+19
  • March 30, 2016
gskibum
  • March 30, 2016
What dpertschi said, plus perhaps removing admin rights from users.
  • March 30, 2016
Stay on top of the release notes so you understand and are aware of new features as they are added. Both major and point releases can have a lot of little and big changes.
  • March 30, 2016
There are some good outlines presented above by others, regarding how you can make good use of Casper over the next few to 5 years. So I won't repeat anything already said.
Hopefully this is what you meant when you mentioned a roadmap. If you meant what JAMF/Casper Suite will look like in the next 5 years, that's pretty difficult to say. Honestly, I'm not sure JAMF has a clear picture where it will be since much of what they can do in their software is dependent on what Apple's adds to their respective OSes.
I think what we can say is that things like:
  • A full patch management framework will definitely be in the product by then
  • 'Sites' functionality will be greatly improved
  • Integration into 3rd party 2FA authentication will probably be there
  • I'm also guessing some more robust reporting will be there (I can only hope!)
Other than that, not really sure. The suggestion to peruse the Feature Request section for clues is a good one, so I'd head there and take a look at ones in the Planned stage, as well as the really popular ones in the Under Review stage for some ideas.
  • March 31, 2016
Wow thanks for all the suggestions. I didn't even know you could look at Feature Requests. That is a great place to start for sure. Luckily, he is a Apple user at home so he knows how much we're at the mercy of them. @gachowski so your not the bad guy.
@dpertschi This is exactly what he is looking for. How we plan to utilize the software he invested in to help the business in the next 3-5 years. Thanks for the ideas everyone.
acodega
Forum|alt.badge.img+15
  • April 1, 2016
For the sake of it, you can also review the 2014 and 2015 JNUC keynotes with him, they are available online.
