Setup unicast or multicast....
  • June 9, 2014
  • 5 replies
  • 14 views
Hi...
Just a quick (maybe stupid) question...
Is there a way to setup or force casper imaging to use unicast or multicast... and if yes how
Forum|alt.badge.img+15
  • June 9, 2014
You can multicast, you just need to use a script to initiate it from Casper Imaging. You'll also need a machine to multicast the image from. Test on a single subnet before trying it across networks.
Not sure where Jamf officially keeps this script now, but here's a copy of it.
# Copyright (c) 2008, JAMF Software, LLC
# All rights reserved.
#   Redistribution and use in source and binary forms, with or without
#   modification, are permitted provided that the following conditions are met:
#       * Redistributions of source code must retain the above copyright
#         notice, this list of conditions and the following disclaimer.
#       * Redistributions in binary form must reproduce the above copyright
#         notice, this list of conditions and the following disclaimer in the
#         documentation and/or other materials provided with the distribution.
#       * Neither the name of the JAMF Software, LLC nor the
#         names of its contributors may be used to endorse or promote products
#         derived from this software without specific prior written permission.
#   THIS SOFTWARE IS PROVIDED BY JAMF SOFTWARE, LLC "AS IS" AND ANY
#   EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
#   WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
#   DISCLAIMED. IN NO EVENT SHALL JAMF SOFTWARE, LLC BE LIABLE FOR ANY
#   DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
#   (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
#   LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
#   ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
#   (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
#   SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
# SUPPORT FOR THIS PROGRAM
#   This program is distributed "as is" by JAMF Software, LLC's Resource Kit team. For more
#   information or support for the Resource Kit, please utilize the following resources:
#       http://www.jamfsoftware.com/mailing_lists/
#       http://www.jamfsoftware.com/jamf_nation/resourcekit.php
#   Please reference our SLA for information regarding support of this application:
#       http://www.jamfsoftware.com/jamf_nation/resourcekit_sla.php
# ABOUT THIS PROGRAM
# NAME
#   MultiCastRestore.sh -- Restore an Image from a server over MultiCast ASR.
# SYNOPSIS
#   sudo MultiCastRestore.sh
#   sudo MultiCastRestore.sh <target> <computerName> <currentUsername> <server>
#   If the $target parameter is passed from The Casper Suite, this is the volume to which the image
#   will be restored.  If the $server parameter is passed from the Casper Suite, this is the server
#   that will be referenced when looking for the image to restore.
#   If the target or server parameters are hardcoded in this script, they will override any
#   parameter that has been passed from The Casper Suite.
# DESCRIPTION
#   This script restores an image from a server running the Casper MultiCast Server tool.  The image
#   will be restored over a multicast session and should be run as a script with a priority of
#   "before" so that it restores the OS image before installing any other packages.  The script also
#   expects that the "Casper MultiCast Server" application is launched and and is actively serving
#   an image.  For more information on performing a multicast image restore, please see the
#   documentation for Casper MultiCast that is included in the JAMF Software Resource Kit.
# HISTORY
#   Version: 1.2
#   - Created by Zach Halmstad on October 28th, 2007
#   - Modified by Nick Amundsen on August 11th, 2008
#   - Modified by Nick Amundsen on March 5th, 2009
# DEFINE VARIABLES & READ IN PARAMETERS
# HARDCODED VALUES ARE SET HERE
target=""
server="10.10.10.10"
# CHECK TO SEE IF A VALUE WAS PASSED IN PARAMETER 1 AND, IF SO, ASSIGN TO "target"
if [ "$1" != "" ] && [ "$target" == "" ];then
    target=$1
# CHECK TO SEE IF A VALUE WAS PASSED IN PARAMETER 4 AND, IF SO, ASSIGN TO "server"
if [ "$4" != "" ] && [ "$server" == "" ]; then
    server=$4
# SCRIPT CONTENTS - DO NOT MODIFY BELOW THIS LINE
if [ "$target" == "" ]; then
    echo "Error:  There is no value defined for the target parameter."
    exit 1
if [ "$server" == "" ]; then
    echo "Error:  There is no value defined for the server parameter."
    exit 1
devEntry=$(/usr/sbin/diskutil info "$target" | /usr/bin/grep "Device Node" | /usr/bin/awk '{print $3}')
echo "The dev entry for the disk to be restored: $devEntry"
originalName=$(/usr/sbin/diskutil info "$target" | /usr/bin/grep "Volume Name" | /usr/bin/grep -o '[^:]*$'  | /usr/bin/tr -s " " | /usr/bin/sed 's/^[ ]//g')
echo "The disk name: $originalName will be retained upon restoring."
echo "Initiating restore process and waiting for connection..."
/usr/sbin/diskutil unmount $devEntry
/usr/sbin/asr restore -source asr://$server -target "$devEntry" -erase -noprompt -timeout 0 -noverify --verbose
/usr/sbin/diskutil mount $devEntry
/usr/sbin/diskutil rename $devEntry "$originalName"
exit 0;
  • June 10, 2014
Thanks for that...
i assume the two info i need to pass in is target referring to my Macintosh HD ? and my ip adress of my deploying server...
  • June 10, 2014
Whats the proper way of writing the target ?
/Volumes/Macintosh HD ?
Macintosh HD ?
Macintosh HD ?
  • June 10, 2014
I just leave target blank and it gets passed through from Casper Imaging.
  • June 10, 2014
what about the multicast adress in the utility... is this my server adress ?
