I've read through the (other post) about installing the VL version of Office 2016 multiple times, but I can't seem to come up with a working install.
I've tried installing the VL version downloaded from the Microsoft VL site which is 15.18 and I've tried the 15.19.1 installer and the serializer. Either way I get an installation in which none of the applications will launch. All give a similar error to the one copied below. I've seen one other person post this exact error, but didn't see a response to the issue.
The current test configuration is simple. It only includes OS X 10.11.4, scripts to set the time and join WiFi, and the Office installer and serializer. After being enrolled in Casper a policy runs that joins it to the domain and creates a local admin account. That's it.
If I use Casper Remote to push the exact same installer to the computer that ran during imaging the applications work. If I push updates to the computer for the 15.20 versions of all apps except Outlook (15.19.1 for it)...the apps work.
I would appreciate any help.
Process: Microsoft Word [1674]
Path: /Applications/Microsoft Word.app/Contents/MacOS/Microsoft Word
Identifier: com.microsoft.Word
Version: ???
Code Type: X86 (Native)
Parent Process: ??? [1]
Responsible: Microsoft Word [1674]
User ID: 501
Date/Time: 2016-03-30 10:34:51.167 -0500
OS Version: Mac OS X 10.11.4 (15E65)
Report Version: 11
Anonymous UUID: 658BB8A2-D913-EDA0-EA0C-9442B131535B
Sleep/Wake UUID: C1041521-4CA3-4F0F-8A73-975DB1D3A55E
Time Awake Since Boot: 1700 seconds
Time Since Wake: 450 seconds
System Integrity Protection: enabled
Crashed Thread: 0
Exception Type: EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000002, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Application Specific Information:
dyld: launch, loading dependent libraries
Dyld Error Message:
Library not loaded: @rpath/mbukernel.framework/Versions/A/mbukernel
Referenced from: /Applications/Microsoft Word.app/Contents/MacOS/Microsoft Word
Reason: image not found
Binary Images:
0x8feee000 - 0x8ff2267f dyld (360.21) <872065EE-ED21-3B30-96A5-2CC56D735FB7> /usr/lib/dyld
Model: MacBookAir7,2, BootROM MBA71.0166.B08, 2 processors, Intel Core i5, 1.6 GHz, 4 GB, SMC 2.27f2
Graphics: Intel HD Graphics 6000, Intel HD Graphics 6000, Built-In
Memory Module: BANK 0/DIMM0, 2 GB, DDR3, 1600 MHz, 0x80AD, 0x483943434E4E4E384A544D4C41522D4E544D
Memory Module: BANK 1/DIMM0, 2 GB, DDR3, 1600 MHz, 0x80AD, 0x483943434E4E4E384A544D4C41522D4E544D
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x117), Broadcom BCM43xx 1.0 (7.21.95.175.1a6)
Bluetooth: Version 4.4.4f4 17685, 3 services, 27 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
Serial ATA Device: APPLE SSD SM0256G, 251 GB
USB Device: USB 3.0 Bus
USB Device: BRCM20702 Hub
USB Device: Bluetooth USB Host Controller
Thunderbolt Bus: MacBook Air, Apple Inc., 27.2
