Error when pushing out .pkg via Casper REMOTE
  • March 11, 2010
  • 0 replies
  • 10 views
I'm having an issue pusing a package via REMOTE.
It installs fine locally or pushing out via ARD.
Below is the error message:
/usr/sbin/jamf is version 7.1
Executing Policy 2010-03-11 at 5:04 PM | admin | 15 Computers...
Downloading BOM for 044YE.pkg...
Downloading Components of http://lonosx1:80/CasperShare/Packages//044YE.pkg...
Installing LMS BDI RECON...
Installation failed. The installer reported: 2010-03-11 17:04:54.553 installer[8455] IFPkg::_parseOldStyleForLanguage - can't find .info file (044YE)
installer: Error the package path specified was invalid: '/Library/Application Support/JAMF/Downloads/044YE.pkg'.
Enforcing Management Framework...
The Management Framework will be enforced as soon as all Policies are done executing.
If I delete the JAMF folder on the target machine in /Library/Application Support/JAMF it will work.
Does anyone know what the problem is?
Regards,
Myron Joffe
Senior Mac Engineer
JWT London IT Department
myron.joffe at jwt.com
Telephone: 020 7656 7033
