Installing 10.15.x Catalina
  • November 4, 2019
  • 17 views
I have a command set to install the 'Install macos Catalina.app' application but where I am getting hung up is it is still asking for an administrator user name and password when trying to install on the system volume. Is there anyway that this can be an authenticated command so that it doesn't prompt the end-user for credentials they will not know?
Setup: I've simply queued the app and ran an execute command "sudo open -a Install macos Catalina.app"
But the minute it tries to install...BOOM "enter admin user name and password"...
Please help!
Best answer by mm2270
You should be using the startosinstall command located inside the app at ./Install macOS Catalina.app/Contents/Resources/
Do searches here for older posts on automated upgrades/installs of High Sierra and Mojave for more on how to use it. But the gist is usually something like:
/path/to/Install macOS Catalina.app/Contents/Resources/startosinstall --nointeraction --agreetolicense
You can see the commands by doing
/path/to/Install macOS Catalina.app/Contents/Resources/startosinstall --usage
  • November 4, 2019
  • November 4, 2019
Thank you!
