9.82 Java Plugin not loading
  • April 1, 2016
  • 6 views
Hi
We've just upgraded to 9.82 and now our custom Java plugin is not loading.
I've tried removing our plugin and testing with the example code, but none of the event notifications are showing as registering in the log.
Has anyone else seen this, or have any ideas?
Many thanks
Dave
1 reply
What version of Java are you using? Have you contacted your TAM?
