Webadmin for NetSUS -- missed
  • July 16, 2018
  • 6 replies
  • 43 views
Hey All,
Hope all are doing well. Need suggestions on this.
For some reason not able to login NetSUS webconsole. Checked list of users cut -d: -f1 /etc/passwd , surprisingly , there is no webadmin account listed.
Please suggest on this.
Best answer by ukspvmalapati
Thanks @mark.mahabir -- this helped me a lot.
I did spend few hours to analyse the issue and found this is an issue with disk space. And After adding some more space able to login.
try these steps guys -- just FYI -- I know you guys are genius.
1) df -h -- will provide occupied size of the server
2) sudo vgdisplay -- will have details of occupied and free space
3) sudo lvextend -l +100%FREE /dev/mapper/NetSUS-root --- to assign 100% of your free space to server volume
4) sudo resize2fs -p /dev/mapper/NetSUS-root -- this will extend the partion
5) sudo vgdisplay -- check free space available now -- it should be 0% now.
  • July 16, 2018
Adding to the above one-- can we delete deprecated packages from Netsus server? am using 4.0 version
mark_mahabir
  • July 17, 2018
When we last ran into this issue, it was all down to disk space.
  • July 17, 2018
  • July 17, 2018
can we delete deprecated packages from Netsus server? -- still didn't got the solution
mark_mahabir
  • July 18, 2018
Does the solution here help at all?
  • July 18, 2018
@mark.mahabir - Yes that worked just to remove deprecated entries from Branches.
