We want to install the LastPAss extension for Safari on our iMacs.
First the LastPass app has to be installed on the iMac. Then, and this is the tricky part, the LastPass extension is available in Safari > Preferences > Extensions, but its unchecked by default.
Is there a way to check the the LastPass extension in Safari with Jamf (plist, script)?
Did you ever get an answer on this? I would like to also deploy the lastpass chrome extension :)
