Retail DVD, Mac OSX with Casper Imaging - errors
  • March 22, 2010
  • 11 views
Gang,
I've hit an impasse and can't seem to use Casper Imaging with
installing the 10.4.6 retail version of the OSX DVD. My goal: have a
simple way to take deployed Macs and erase/re-image with the stock
config that would come from using the DVD installation. To accomplish
this goal, I:
+ Created a compressed DMG from the DVD made using disk utility
+ Uploaded the DMG to Casper Admin
+ Tagged it as an OSX Installer Disk
+ Did NOT create a custom installer, just left the installer "as-is"
+ Added that one file into a configuration with NOTHING ELSE (scripts,
pkg's, printers, etc.)
+ Netbooted to our master netboot image (from which run all of our
imaging) and called that configuration.
The results vary.
+ Sometimes the installation acts as if the file is not a valid
installer and finishes up within 15 seconds.
+ Sometimes the installation will run but the computer fails on
reboot. Examining the drive shows that a full installation has been
laid down but that there's an odd "etc 1" folder in the root directory
with another directory inside called "xinetd.d-migrated2launchd".
never seen that one before...
+ Once, the installation did complete and the computer DID boot but
loaded a login screen which, of course, left me confused. As we'd not
called for any accounts to be created.
A fresh install from the retail DVD should produce a Mac where booting
up takes you to a welcome screen movie, followed by a first-run
wizard. Why, on earth, is this seeing to be so difficult?!
I know, I know... if I wanted I COULD install the DVD and then make an
image and upload that image to Casper Admin but... you know: this way
is supposed to work, so...
1 reply
Forum|alt.badge.img+21
  • March 22, 2010
And just to be certain you are only trying to make these images work on hardware that was purchased before Leopard's release and not newer hardware, right?
Craig Ernst
UW-Eau Claire
(715) 836-3639
Sent from my iPhone
