Import device command/script for VirtualBox policy
  • November 8, 2019
  • 8 views
I'm trying to accomplish the following: I've got a policy in Jamf that allows users to download the VirtualBox application from Self Service (that part works fine). When the application gets installed to an endpoint, I'd like to then import a device into VirtualBox.
I exported the device from VirtualBox as a .ova file, then created a package with this file via Composer and uploaded into Jamf, but for the life of me, I cannot get it to import. I've tried:
  • In the VirtualBox policy that contains the device package, using Files and Processes>Execute Command
vboxmanage import /Users/Shared/google_nexus_10.ova
(note: this command accomplishes the desired result when ran locally from Terminal)
  • Including this script in the policy to run "After" the device package installs
!/bin/bash
  • I also tried packaging the device in Composer with the above script as a postinstall
The Jamf policy details show the import command and script attempts as running successfully, however, the device does not actually import.
I'm tapped out with both my limited knowledge of scripting and Jamf, so truly any suggestions would be appreciated!
1 reply
  • November 13, 2019
Jeremy Nelson from Jamf was able to resolve my issue. If anyone is curious, the fix was to run the script as the current user. So that resulted in this:
user=stat -f '%Su' /dev/console
su $user vboxmanage import /Users/Shared/google_nexus_10.ova
