Install latest version of Google Chrome without re-packaging
  • August 17, 2016
  • 94 replies
  • 928 views
Hey everyone...
I wanted to make Google Chrome a part of my automated deployment process and also be available within Self-Service.
Why? Users can just download from Google on their own. True dat. But hey, one-stop shopping in Self-Service, right?
As we all know, Google deploys Chrome via a DMG file. The Google Chrome.app file must be dragged to the /Applications folder.
You could effectively re-package everything using Composer, but then things get REAL STALE, REAL FAST - Google updates Chrome frequently. So stale software is bad software.
So how can we deploy Google Chrome with the freshest of the fresh so we don't get that not-so-fresh feeling?
Well, lemme share my story, morning glory.
THE SCRIPT
I wrote a simple script that does the heavy lifting...
I tossed this script into System Settings > Computer Management > Scripts within the JSS...
NOTE: Yes, I am aware that I don't have any error checking taking place. This is v1.1 - quick and dirty. Feel free to add some if you feel the need.
# Google Chrome Installation Script
# DESCRIPTION
# Automatically download and install Google Chrome
# HISTORY
# Created by Caine Hörr on 2016-07-25
# v1.1 - 2016-10-11 - Caine Hörr
# Added -nobrowse flag to hdiutil attach /tmp/$VendorDMG command line arguments
# Shout out to Chad Brewer (cbrewer) on JAMFNation for this fix/update
# https://jamfnation.jamfsoftware.com/viewProfile.html?userID=1685
# v1.0 - 2016-07-25 - Caine Hörr
# Google Chrome Installation script
# Vendor supplied DMG file
VendorDMG="googlechrome.dmg"
# Download vendor supplied DMG file into /tmp/
curl https://dl.google.com/chrome/mac/stable/GGRO/$VendorDMG -o /tmp/$VendorDMG
# Mount vendor supplied DMG File
hdiutil attach /tmp/$VendorDMG -nobrowse
# Copy contents of vendor supplied DMG file to /Applications/
# Preserve all file attributes and ACLs
cp -pPR /Volumes/Google Chrome/Google Chrome.app /Applications/
# Identify the correct mount point for the vendor supplied DMG file
GoogleChromeDMG="$(hdiutil info | grep "/Volumes/Google Chrome" | awk '{ print $1 }')"
# Unmount the vendor supplied DMG file
hdiutil detach $GoogleChromeDMG
# Remove the downloaded vendor supplied DMG file
rm -f /tmp/$VendorDMG
SMART COMPUTER GROUP
We need a Smart Computer Group so Policy #1 has something to work from...
Computer Group
Display Name = "Google Chrome - Not Installed"
Criteria
[Application Title] [is not] [Google Chrome.app]
POLICY #1
This policy makes things happen auto-magically based on the aforementioned Smart Computer Group.
Policy: Options
General
Display Name: "Download & Install Google Chrome"
Enabled = Checked
Triggers = Login, Recurring Check-In, Make Available Offline
Execution Frequency = Ongoing
Make Available Offline = Checked
Scripts
Points to the script in System Settings > Computer Management > Scripts
Priority: After
Maintenance
Update Inventory = Checked
Policy: Scope
Target Computers = Specific Computers
Target Users = Specific Users
Target/Type = "Google Chrome - Not Installed" Smart Computer Group
POLICY #2
I wanted a second policy for the sole purpose of Self-Service. I did not want the user's ability to download/install Google Chrome to be hindered within Self-Service by them being out of scope.
Why?
Perhaps the user's version of Chrome isn't updating properly... they can go to Self-Service and download/install at their leisure. There may be other reasons.
Policy: Options
General
Display Name: "Google Chrome (Latest Version)"
Enabled = Checked
Scripts
Priority: After
Maintenance
Policy: Scope
Target Computers = All Computers
Target Users = All Users
Policy: Self Service
Make the policy available in Self Service = Checked
Description: Download and install the latest version of Google Chrome
Icon: I ripped the Google Chrome 128x128 icon from the icon file found within the Google Chrome.app
Feature the policy on the main page = Checked
Anyway - That's about it. It's a simple workflow.
  • Chrome will auto-install on machines without Chrome
  • Chrome can be manually installed via Self-Service
  • Chrome will always be fresh when installed
Feel free to salt-to-taste - even better if you share your changes.
Cheers!
Best answer by cbrewer
If you use
it will keep the volume from popping up in Finder.
Forum|alt.badge.img+15
  • August 17, 2016
If you use
  • October 11, 2016
Does this have the downside that the user's machine will continuously re-download the DMG whenever a user logs in, or when the machine checks in with JAMF?
Not criticizing, just trying to understand.
stevewood
Forum|alt.badge.img+38
  • October 11, 2016
@nojorge no, it should not. If you look at the scope for Policy #1, @caine.horr is scoping to the SmartGroup he created that looks to see if Chrome is installed. If Chrome IS installed, the machine does not fall into the SmartGroup and thus will not fall into scope for Policy #1.
  • October 11, 2016
Great script. This will be very useful and time saving.
  • October 14, 2016
Been using something similar for lots of clients for over a year and works really well (except when proxy's get in the way).
Might be worth adding a few checks to the script though e.g: https://github.com/gavinpardoe/Scripts/blob/master/installChrome.sh
Just went live with it and have already seen the number of machines running the current version increase.
Wonderful!!
  • August 16, 2017
Thanks for the script. It works great. Except..
I do get an error after Chrome installs saying it could not be installed and contact your Admin...
  • August 28, 2017
Thanks for putting this together, works great! Do you think we can modify this to work with other applications like Adobe Acrobat Reader or Firefox? We're not installing these browsers on enrollment so having an always up to date package in Self Service would be amazing.
Thanks again!
Edit: Found this! https://www.jamf.com/jamf-nation/discussions/12042/adobe-reader-update
Thanks!!
  • September 2, 2017
What a great idea and so neat and clean and simple. I wish I thought of it, thanks for sharing!
  • May 2, 2018
When looking for a way to install Chrome from the command line, I found this discussion. The meaty goodness is here:
temp=$TMPDIR$(uuidgen)
mkdir -p $temp/mount
curl $4 > $temp/1.dmg
yes | hdiutil attach -noverify -nobrowse -mountpoint $temp/mount $temp/1.dmg
cp -r $temp/mount/*.app /Applications
hdiutil detach $temp/mount
rm -r $temp
In the Policy, set Parameter 4 to https://dl.google.com/chrome/mac/stable/GGRO/googlechrome.dmg
It's not nice & commented, but it's really elegant. The user has no idea it's happening. This also will work for other packages, by simply changing the source URL (paremeter 4). It also cleans up after itself.
The major improvement over the OP's script is that line that starts with "yes". That will auto-accept any licensing pop-ups that mounting the DMG might make.
  • May 8, 2018
Hi @JayDuff
I tried your script but it didn't work :( Shows completed, but I didn't get an install. Here are the details within jamf pro
  • May 8, 2018
Hi @ryan.er - It looks like the image had a problem. I'd say try it again. Also, triple check your Parameter 4.
I tested it with the link hardcoded in. So
was
curl https://dl.google.com/chrome/mac/stable/GGRO/googlechrome.dmg > $temp/1.dmg
in my test.
Maybe there is a problem with $4?
  • August 30, 2018
Does anybody know what the new download link is? We've been using this script for the longest time and it's worked until now. When i try to go to the download link it doesn't exist anymore
# Vendor supplied DMG file VendorDMG="googlechrome.dmg"
  • August 30, 2018
Forum|alt.badge.img+23
  • August 30, 2018
  • November 1, 2018
Great script! Worked for me! But...
After installation and when Chrome opened for the first time, It gave me the Auto-Update alert. I had the option to either Enable or Cancel(?) the auto updater. When I hit enable, it prompted me to enter an Administrator password. Is there way to bypass the need for an Admin password for the auto updater? Or better yet, script to allow the Auto Updater to enable without prompting the user?
My environment has all employees as Standard Users.
I also noticed my 1Password Chrome extension won't work if the Chrome Browser can't check for updates (weird... but is this just me?)
  • November 1, 2018
I answered my own question with a little more digging into Jamf Nation:
Jamf Nation Discussion : Force Enable Google Chrome Automatic Updates
What I did:
  1. I downloaded this script, added it to our JSS cloud server. Then I set to Script>Option>Priority = After.
  2. I then added it to the Policies mentioned in the original post of this discussion.
In JSS, if you have more than 1 script in a Policy, they will run in Alphabetical Order. Just make sure the "Google Chrome (Latest Version)" script is named alphabetically before the enable auto-update script.
Thanks again @cainehorr and everyone else involved in this discussion!
  • November 1, 2018
Nice script, but wondering what options is there to auto update chrome as soon there is a new version - or at least update chrome versions that maybe are outdated as self service is not always something users look at
  • November 2, 2018
@kcsantos The reason auto-updating doesn't work on most non admin accounts is that the updater is stored in ~/library by default. Running an application from there requires admin credentials. By running the script you posted above the updater gets moved to /library like it should be, allowing it to run.
  • November 20, 2018
I have been using this script for over a year. It has been great. Much thanks to cainehorr and anyone else who worked on it. I did just start having an issue though. I deployed this script to a few test machines and also ran it manually to be sure. After the script is applied Chrome will not open unless the machine is restarted. Anyone else run into this problem and found a solution or updated the script?
  • February 4, 2019
Awesome script @cainehorr!!
I created a modified version of it that will take just about any app installer direct download link and install the app, regardless of type of packaging. It's worked out great for us so far, I created a template script & policy in Jamf, so all that's needed to create a new app installer is clone the script, paste in the DL link in the script, clone the policy, and add the newly cloned script to the policy.
The one caveat here is installers that are packaged as a .app (e.g. Adobe CC menu bar item). This script still works, but just dumps the <installer name>.app into the /Applications folder.
Anyways, I haven't really worked with bash or Jamf scripts too much yet, so I'd love some feedback if y'all would be willing to share! Some additional verification logic might be helpful for the if/then statements, but I haven't noticed any negative results so far.
# Universal App Installer Script
# DESCRIPTION
# Automatically download and install nearly any app from a direct download link
# App can be packaged as .dmg, .pkg, or .zip, and have either the .app or a .pkg inside
# HISTORY
# Created by Ella Hansen on 10/30/2018
# v1.0 - 10/30/2018 - Ella Hansen
# Created script based on Caine Hörr's script for Google Chrome:
# https://www.jamf.com/jamf-nation/discussions/20894
# ADD THE DIRECT DOWNLOAD LINK FOR YOUR APP HERE:
# Example: DownloadURL="https://dl.google.com/chrome/mac/stable/googlechrome.dmg"
DownloadURL="___"
# LEAVE THIS CODE ALONE:
# Create directory /tmp/jamf, continue if directory already exists
mkdir /tmp/jamf || :
# Change directory to /tmp/jamf
cd /tmp/jamf
#Download installer container into /tmp/jamf
# -O downloads file without changing its name
curl $DownloadURL -O -L
# If container is a .dmg:
# Mount installer container
# -nobrowse to hide the mounted .dmg
# -noverify to skip .dmg verification
# -mountpoint to specify mount point
yes | hdiutil attach /tmp/jamf/*.dmg -nobrowse -noverify -mountpoint /tmp/jamf/mount ||
# Else if container is a .pkg
# Run installer package with the boot drive as the destination
installer -pkg /tmp/jamf/*.pkg -target / ||
# Else if container is anything else, presumably a zip file:
# Unzip installer container and place contents into /tmp/jamf/mount, continue on error
unzip /tmp/jamf/* -d /tmp/jamf/mount || :
# If contents is installer .pkg:
installer -pkg /tmp/jamf/mount/*.pkg -target / ||
# Else if contents is .app:
# Copy the .app file from the installer container to /Applications
cp -pPR /tmp/jamf/mount/*.app /Applications || :
# Unmount the secondary installation folder, continue on error
hdiutil detach /tmp/jamf/mount || :
# Delete the main installation folder
rm -r /tmp/jamf
sjha967
  • February 5, 2019
https://github.com/hjuutilainen/adminscripts/blob/master/chrome-enable-autoupdates.py
  • February 7, 2019
@ellavader that. is. awesome.
I made a quick change to avoid having to duplicate and edit the script.
DownloadURL="$4"
This way I can add the URL as a parameter from the policy creation window.
I'd love to stay in the loop on this for "additional verification logic"
  • February 8, 2019
Maybe this question would be better answered in its own thread but here goes:
Where and how do you find ATOM feeds and download links to use with scripts like this? I'd like to use this for a variety of things that aren't part of the patch management framework.
  • February 9, 2019
Awesome script @ellavader & @cainehorr - Thanks a lot, that saved a lots of time from our side ! Is there a way to enhance the script by downloading & Installing the latest version only when there is a new version of Chrome released ?
Seems that script is continuously upgrading at each checkin time that is not good for an end-user if he has bad network... ! We can also space the checkin by a week or a month which is ok as a workaround.
Best,
