App Store Images not loading
  • April 6, 2016
  • 5 replies
  • 35 views
Our network team have made some changes to the Palo Alto and now Mac App Store images aren't loading.
All we get are placeholders
They've allowed the 17.0.0.0/8 range but it appears that the images are hosted elsewhere.
Does anyone know what else we need to unblock to resolve?
Thanks
Al
Best answer by al_platt
As suspected, the apps themselves and text are hosted with Apple but the images are still using Akamai.
davidacland
  • April 6, 2016
Not sure, but wire shark would tell you if you run it on a Mac while launching the App Store.
  • April 7, 2016
Thanks David, that was my next step, thought i'd ask the nation first though!
  • April 7, 2016
  • April 15, 2016
Hi, please can you advise how to fix it. Have exactly the same problem as you above, however, when connecting via ethernet, all images load. I can see the images are hosted at http://a1.mzstatic.com...
davidacland
  • April 15, 2016
@dnx im assuming you will have different web filtering and/or firewall rules in place in wireless and wired connections.
You will need to look at the rules that are set up and change them to allow the traffic.
