Does anyone know if JAMF is adding a Siri restriction in Config Profile MDM to the next revision? Or how I can stop SIRI Popup for all of my AD users when they log on?
Hey @dmichels this post will probably contain the answers you're looking for:
https://www.jamf.com/jamf-nation/discussions/9068/disable-mavericks-sign-in-with-your-apple-id-at-login-prompt
jamf can only provide what Apple allow in profiles however you can add custom settings. here are some for SIRI by Rich Troughton.
If you use a Configuration Profile, in the LoginWindow section you click on Disable Apple ID during login and it will disable the Siri prompt as well.
