Make Adobe Acrobat the Default PDF Viewer
  • May 30, 2019
  • 4 replies
  • 44 views
Hello,
Anyone have a command or script that is working for them to make Adobe Acrobat the default PDF viewer for all users?
  • June 3, 2019
I ended up using Compose to capture the change to ~/Preferences/com.apple.LaunchServices
  • November 18, 2019
@dtmille2 Did this work??
  • November 18, 2019
https://www.jamf.com/jamf-nation/discussions/30016/set-acrobat-reader-dc-as-the-default-pdf-handler#responseChild175405
  • November 18, 2019
Yes, @dstaubitz , at the time it did. Not sure with Catalina.
