Hi All,
Wonder if anyone on the list uses First Class, and if so, when you
view Application Usage Logs in the JSS, does FirstClass have dozens of
slashes after the name of the application? This happens with multiple
client versions, to varying degree.. (see attached file)
Consequence being that instead of a small to medium sized window
showing applications to the left and time in use to the right, I have
to view in a giant window AND also sometimes reduce my font size.
This makes these logs somewhat less than optimum. (would LOVE to be
able to export them...)
Anyone see this or have ideas how to fix?
Sandy
