How to tell if Time Machine is being used
  • April 13, 2010
  • 10 replies
  • 34 views
Hey Guys-
Anybody have an idea on how we could tell, using Casper, if Time Machine is
being used on a system? We have switched everyone over to using Crashplan
want to find anyone who might still be using Time Machine and turn them off.
Thx
Jon
-- Jonathan H. Smith | Sr. Systems Engineer | Genentech Informatics| office:
650-225-4968| mobile: 650-302-6985 | smith.jonathan at gene.com |
If you're running 7.2 of the JSS you could utilize the Extension Attributes in Inventory to display the Time Machine status.
Incidentally you can leverage the attributes for CrashPlan as well for policy decisions.
  • April 13, 2010
Thanks Lance, I'll look into that. We are still testing 7.2 but good to know
when we make the switch. Anyway to do that in 7.1?
Thx
Jon
Forum|alt.badge.img+23
  • April 13, 2010
dummy packages. :)
Extension attributes are better, and this is Mr. Dummy Package talking.
I hope this helps.
Thanks,
Miles
Forum|alt.badge.img+31
  • April 13, 2010
Why not just turn it off?
defaults write /Library/Preferences/com.apple.timemachine AutoBackup -bool false
Manage it with a 1 liner or MCX
  • April 13, 2010
Hey Tom-
That is the ultimate goal but right now we are just being asked for the
number of systems that still have Time Machine enabled. Things are very "1
step at a time around here". I'll keep that command though for when we need
to do the deed.
Jon
  • April 13, 2010
Well, if you turn it off you can then just log your help desk calls of those who can't use it and voila you got your numbers right there hahahahaha
Just kidding....
  • June 21, 2016
I know I'm bumping a very old thread, but I've found part of the answer I was looking for, and I'm hoping someone can answer the second part.
We are looking to use the JSS to give us an idea of which machines don't have Time Machine enabled. I now see that it's listed under Extension Attributes for the individual machines, but I'm wondering if there is some criteria in the Smart Groups that may allow us to get an overview of how many and which ones?
I've got a Smart Group that tells us which ones haven't backed up in over 30 days, but that doesn't report on which machines have never had Time Machine set up in the first place.
  • June 21, 2016
Ok, I worked it out
Because the EA was set as reporting a date, rather than a string, I was unable to set a smart group based on the result 'not enabled'.
I duplicated the EA, just so I didn't lose my other smart group, and changed the duplicated one to reporting a string. I was then able to set the criteria in my smart group to being 'not enabled'. Once I did that, I started to get the results we were looking for.
  • June 21, 2016
I don't have any machines on my network running with time machine right now but id imagine you would be able to do some thing with
tmutil latestbackup
tmutil listbackups
  • June 21, 2016
This to..
tmutil destinationinfo
If it's not configured it returns "tmutil: No destinations configured." If it was configured it might be useful to awk || grep for the name or path to the backup location.
