Creating a package for System Certificates?
  • November 15, 2019
  • 50 views
Hi all,
I'm looking to create an installer for my setup process that would install certificates in the System keychain and set them to always trusted. What would be the best way to create such a .pkg?
  • November 15, 2019
I would suggest to use a profile with the payload a certificate. If needed you can download the profile to install without enrollment.
chrisB
  • November 15, 2019
Check the following answer:
https://www.jamf.com/jamf-nation/discussions/22294/adding-a-certificate-to-the-system-keychain-set-to-always-trust
  • November 15, 2019
I have read someplace that Apple has deprecated using the CLI to add certs... That said I couldn't find it so I could be totally wrong..
As I typed this I think it's in the Catalina documentation from Apple or a WWDC presentation..
Sorry but that my long way of saying "got to start using an MDM/Config Profile.."
C
