Hi
I hope I am posting this in the right location. If not please let me know where I should.
The issue I am having is after a new install of NetSUS 4.0.0 and running the sync
for the first time I get one error on top of the software update branch that says
Under Name = Product 031-00553 is missing the sort key PostDate -- Product info database
Under Version = may incomplete
Under Date = be
Under the blue info icon it says = no product id found WARNING:
Thanks
Dave
Not sure what changed, but I loaded NetSUS 4.0.0 VM again and ran the sync
overnight and everything looks fine now.
Thanks
Dave
hi; @dforman
Can you see the last mac os x updates ( 10.11.3.or 10.11.4 ) on the NetSUS 4.0.0 also which url are you using for El-capitan Osx ?
Thank you
Thanks for the reply
The latest update is:
OS X El Capitan Update version 10.11.4 date 2016-04-11
Not sure why but there are 3 listed and I have a number of updates that have double listing
like Safari 9.1
I am using the default URLs
/etc/apache2/sites-enabled/000-default.conf
vim: syntax=apache ts=4 sw=4 sts=4 sr noet
<IfModule mod_rewrite.c>
RewriteEngine On
RewriteCond %{HTTP_USER_AGENT} Darwin/9
RewriteRule ^/index.sucatalog$ http://%{HTTP_HOST}/index-leopard.merged-1.sucatalog
RewriteCond %{HTTP_USER_AGENT} Darwin/10
RewriteRule ^/index.sucatalog$ http://%{HTTP_HOST}/index-leopard-snowleopard.merged-1.sucatalog
RewriteCond %{HTTP_USER_AGENT} Darwin/11
RewriteRule ^/index.sucatalog$ http://%{HTTP_HOST}/index-lion-snowleopard-leopard.merged-1.sucatalog
RewriteCond %{HTTP_USER_AGENT} Darwin/12
RewriteRule ^/index.sucatalog$ http://%{HTTP_HOST}/index-mountainlion-lion-snowleopard-leopard.merged-1.sucatalog
RewriteCond %{HTTP_USER_AGENT} Darwin/13
RewriteRule ^/index.sucatalog$ http://%{HTTP_HOST}/index-10.9-mountainlion-lion-snowleopard-leopard.merged-1.sucatalog
RewriteCond %{HTTP_USER_AGENT} Darwin/14
RewriteRule ^/index.sucatalog$ http://%{HTTP_HOST}/index-10.10-10.9-mountainlion-lion-snowleopard-leopard.merged-1.sucatalog
RewriteCond %{HTTP_USER_AGENT} Darwin/15
RewriteRule ^/index.sucatalog$ http://%{HTTP_HOST}/index-10.11-10.10-10.9-mountainlion-lion-snowleopard-leopard.merged-1.sucatalog
</IfModule>
</VirtualHost>
