I have users connecting to an internal update server that I'm taking offline and would like to point these users to apple's software updates server during this time.
How can I accomplish this?
Nevermind, delete the configuration profile in the JSS then run
sudo /usr/local/bin/jamf removeSWUSettings
on clients and that clears things out.
if it's coming from a configuration profile, removing that profile should remove that setting. Then you may follow that up with a
/usr/sbin/softwareupdate --clear-catalog
softwareupdate: Changed catalog to Apple production
and you should be back to normal. Try verifying with a
defaults read /Library/Preferences/com.apple.SoftwareUpdate.plist
It was coming from a configuration profile but even after removing the configuration profile the settings were still defaulting to our internal servers. This line here did resolve the problem. I find this... strange.
I did try the things you mentioned, though. They had no effect for some reason.
I've experienced it where I have to do a remove framework to get everything JAMF off of it, then it removes the corrupt profile. Re-enroll and things are fine.
I do wonder if its related to MDM. Trying to manually remove stubborn profiles with a
profiles remove -identifier stubborn-uuid-of-profile
profiles remove for identifier:'stubborn-uuid-of-profile' and user:'admin' returned 101 (Profile is not removable.)
