Install Salesforce1 mobile app with no iTunes Apple ID
  • May 11, 2017
  • 10 replies
  • 75 views
I believe this has something to do with VPP / Device Assignment.
Just want the app (as well as others) to be installed at the time the iPhone is enrolled / CP applied.
thx, John
  • May 11, 2017
using VPP, the end user will not need to enter in an Apple ID to install or update.
  • May 11, 2017
Salesforce1 is a free app, and I have it checked, under VPP “Device Assignments” is visible, when click “Edit”, can briefly see the page change, but nothing changes on the page.
thx, j
mpermann
Forum|alt.badge.img+22
  • May 11, 2017
@johnklimeck I still "buy" the free apps on the Apple VPP portal page and then get added to my JSS. Then I can assign them. Have you purchased some licenses from the VPP portal already?
  • May 11, 2017
beat me too it @mpermann
you will need to purchase them through the VPP portal
  • May 11, 2017
I have not done that, assuming I do that, it should work?
thx, j
  • May 11, 2017
that will give you the application in your JSS. you then need to set a policy to install it
mpermann
  • May 11, 2017
@johnklimeck yeah, once you've "purchased" the free app in the VPP portal it will be available for assignment.
  • May 11, 2017
  • May 11, 2017
Got it
  • May 11, 2017
Got it now, thx all.
j
