Hi All,
I am currently on Jamf Pro 10.16.1 but was testing this issue under 10.15.1 until this morning.
Any ipads in our fleet that were running the beta profile (around 7 devices) are now failing to properly inventory within jamf pro.
The Device itself gets all its profiles and apps. But because the inventory update fails, the JSS continually pushes these apps and profiles over and over again.
Is anyone else having this issue? And if so what steps are you taking to mitigate?
Cheers
