Everytime I download it, it gives me the 10.14 installer... grrrrr
Come drink this juice: installinstallmacos.py
I like to use the Dos Dude Mojave Patcher Program
Link and directions here
http://osxdaily.com/2018/09/29/download-full-macos-mojave-installer/
You could use a machine that already has 10.14.1 to grab it form the app store.
@tnielsen
If you have 10.14.2 installed, and try and download it from the store you will get the full installer anything less than 10.14.2 you will get the "upgrade" process...
C
Now, with 10.14.4 installed, when I go back to the App Store and try to "Get" Mojave again, it opens System Preferences and tries to install it as an update eventually failing because I am already up to date.
Ideas?
There used to be an appstore debug menu to go to the downloads folder. Going to see if I can dig up that info and follow that path to maybe get it.
After a couple of tries, the installer did finally decide to show up in my /Applications folder again.
Must've just been a glitch.
@jrippy - I am not seeing that issue here. Also, I'm pretty sure the debug/advanced or whatever has been gone now since maybe 10.13.x.
I tried downloading the installer on two 10.14.4 Macs with no issues.
Shows as ~6.03GB.
*Edit: I see you got it. I'm too slow to post ;)
