Add URL to the App setting using App Configuration Preferences
  • October 19, 2017
  • 16 views
Hello,
Student are using a program by Scholastic "iRead" and the program needs the URL to point the app to the correct server. This year I had to manually type in the URL on all the iPads, around 300 and it took me a long time.
My question, does anyone know how to use the App Configuration Preferences to add the URL using JAMF?
  • September 24, 2018
Hey martinp. Were you ever able to figure out how to add the URL into the app configuration?
Thanks
  • October 11, 2018
Did you ever figure this out?
  • October 11, 2018
This may work. iRead looks to be under the same umbrella as Reading Counts and is now owned/maintained by Houghton Mifflin Harcourt.
