Hi folks. I've been poring over the discussions here in search of an answer to my question, but there's just so much information, and the terms of the search are probably a little too broad to get the results I'm looking for. If there is a discussion answering this question, please point me in the right direction.
We are implementing a new Casper setup, and really beginning to fully manage Macs for the first time. What we wish to do is achieve a zero-touch workflow leveraging DEP and Casper. One problem we seem to be hitting is that we use 802.1X/radius, and it doesn't seem like you're able to join such WiFi networks during the setup assistant. Is this the case, or do we need to check our configuration?
Unless I'm reading something wrong, DEP doesn't actually pre-load any information, but rather forces an enrollment profile on the laptop once it connects to the internet and activates. So, if we are aiming for a custom setup assistant, and other pieces we'd want configured at first login (binding to a directory, security settings, etc.), is it possible to achieve any of this directly out of the box, or will we need to do some level of pre-stage imaging?
We have a session scheduled with JAMF in a few weeks, but we're trying to get as much accomplished in the meantime as possible, and I really appreciate any advice this community may have.
Thanks,
Pete
