Extension Attribute to check for Whitelisted Netboot server
  • August 31, 2016
  • 0 replies
  • 6 views
jmahlman
After upgrading to 10.11 on campus we wanted to find out which machines need our netboot server whitelisted to allow for booting remotely. I put together this quick EA that others may find useful.
osvers_major=$(sw_vers -productVersion | awk -F. '{print $1}')
osvers_minor=$(sw_vers -productVersion | awk -F. '{print $2}')
# Checks to see if the OS on the Mac is 10.x.x.
if [[ ${osvers_major} -ne 10 ]]; then
  echo "Unknown Version of Mac OS X"
# Checks to see if the OS on the Mac is 10.11.x or higher.
if [[ ${osvers_major} -eq 10 ]] && [[ ${osvers_minor} -lt 11 ]]; then
  echo "System Integrity Protection Not Available For `sw_vers -productVersion`"
if [[ ${osvers_major} -eq 10 ]] && [[ ${osvers_minor} -ge 11 ]]; then
    # Checks System Integrity Protection status on Macs
    # running 10.11.x or higher
    SIP_status=`/usr/bin/csrutil status | awk '/status/ {print $5}' | sed 's/.$//'`
    # If it's disabled, just print disabled
    if [[ $SIP_status == "disabled" ]]; then
        echo "<result>SIP Disabled</result>"
        # if it's enabled, we'll get the netboot list
    elif [[ $SIP_status == "enabled" ]]; then
        netbootList=`/usr/bin/csrutil netboot list`
        echo "<result>$netbootList</result>"
