Having a problem with deploying CS4 that I can't crack. At times
during the install, whether deployed with Casper Remote or imaging, I
get one of two error messages.
If Adobe Air is not installed, I get an error saying that Adobe Air is
required for this installation.
If Adobe Air 1.5.3.9130 is installed, I get an error saying this
installer requires an unsupported version of Air.
Problem 1 is that air is not required, as once I click through the
error popup, the install continues to completion and all the apps run
just fine.
Problem 2 is that this error is happening 3-4 times per installation,
and each time it stays hung on that error popup until it's clicked
through.
Has anyone encountered this and/or found a solution to this? The
interwebs elude me.
Regards,
-Sean Hansell
(Sent from my iPhone)
Adweek's 2009 Global Agency of the Year
