Acrobat update administration: Was "Adobe CS4 Install During Imaging"
  • April 26, 2010
  • 28 views
talkingmoose
Forum|alt.badge.img+36
I haven't seen the new Adobe CS5 installers yet, so I can't say anything
On 4/25/10 12:54 PM, "Don Montalvo" <donmontalvo at gmail.com> wrote:
about them. Not holding my breath but cautiously optimistic.
However, we've been told that the Acrobat installer will be a .pkg
installer. That may be good or it may not.
We have licenses for both the full CS suites as well as the individual
installers. Acrobat has always been the challenge, especially after
installation (self-heal, registration, etc.). Yes, we've discovered
workarounds and tools for managing Acrobat's behavior, but I really don't
expect Adobe to "get it right the first time". Moving to an Apple Installer
file is definitely a step in the right direction, though.
With that said, earlier this morning I stumbled upon this document that was
released just a couple of weeks ago from Adobe:
Acrobat-Reader Updater: A configuration and user guide For the Acrobat Product Family 9.2 and 8.1.7 and later
<http://kb2.adobe.com/cps/837/cpsid_83709/attachments/Acrobat_Reader_Updater
.pdf>
The PDF is written for administrators and details the new Acrobat updater
present in both 8.1.7 and 9.2.x. Although it's titled for "Reader", the
introduction says it's for the Acrobat family of products. The document is
for both Mac and Windows and details how to make Windows registry as well as
Mac OS X .plist changes to control the Acrobat updater.
For me, this is another step in the right direction.
William Smith
Technical Analyst
Merrill Communications LLC
(651) 632-1492
  • June 2, 2010
FYI... I just received my 'updated' Adobe CS5 Design Premium media from Adobe Licensing, and the Adobe Acrobat Pro 9 install continues to be a drag and drop into the Applications folder, proceeded by the usual automated self-healing to finish installing the other various bits that are associated with the application.
Sorry to disappoint you...
-- Ted August
Salve Regina University
donmontalvo
  • June 3, 2010
Hi Ted,
"Ted August taugust04.lists at gmail.com wrote:
The above was incorrectly attributed to me...I did some digging, seems that the above was posted by William Smith. I copy/pasted the original quoted text to put things back into context. :)
I know the Acrobat Pro install is a drag-install, and that patches are proper PKG format. So the former is simple enough to package.
Don
