Update Office from 2011 to 2016
  • April 15, 2016
  • 5 replies
  • 54 views
Updating Office from 2011 to 2016 is causing Office 2016 to ask for Activation. We are using same Office 2016 for other Macs and it has never asked for Activation before. This Office 2016 is EES for Education and not the Office 365 setup. The way we are trying to upgrade a Mac (that already has Office 2011) is by installing Office 2016 and then removing Office 2011 using a script. We are trying to avoid the downtime on Ms Office for our end users.
Are you targeting the Office 2011 activation file in the clean up script? If so, are you targeting it directly or doing a blanket removal of any com.microsoft.* files in the /Library/Preferences directory?
  • April 15, 2016
I think we have figured it out.
MS Office 2011 license file is /Library/Preferences/com.microsoft.licensing.plist
MS Office 2011 license file is /Library/Preferences/com.microsoftV2.licensing.plist
Our sequence of action for testing was as follows.
  1. Install Ms Office 2011
  2. Install Ms Office 2016
    This will update the Office 2011 licensing file to Office 2016 license file and there will be no two licensing files in /Library/Preferences/
  3. Remove Ms Office 2011
The script had syntax rm -R /Library/Preferences/com.microsoft.licensing*.plist
which was also removing Ms Office 2016 license file and was causing license information completely missing from the Mac OSX.
We changed the script line from
to
  • April 15, 2016
This is the remove Office 2011 script I use based on one from OfficeforMacHelp. As you have noted, you must specify that licensing.plist, otherwise you may knock out the 2016 licensing plist file too, if you installed that version before removing 2011.
Ideally, you want to remove 2011 first, then install 2016. This script will leave behind the "Microsoft User Data" folder in the user's Documents folder, so it'll be easy to import the Outlook data into the new version. After the data is imported, you can delete the "Microsoft User Data" folder.
    osascript -e 'tell application "Microsoft Database Daemon" to quit'
    osascript -e 'tell application "Microsoft AU Daemon" to quit'
    osascript -e 'tell application "Office365Service" to quit'
    rm -R '/Applications/Microsoft Communicator.app/'
    rm -R '/Applications/Microsoft Messenger.app/'
    rm -R '/Applications/Microsoft Office 2011/'
    rm -R '/Applications/Remote Desktop Connection.app/'
    rm -R '/Library/Application Support/Microsoft/MAU2.0'
    rm -R '/Library/Application Support/Microsoft/MERP2.0'
    rm -R /Library/Automator/*Excel*
    rm -R /Library/Automator/*Office*
    rm -R /Library/Automator/*Outlook*
    rm -R /Library/Automator/*PowerPoint*
    rm -R /Library/Automator/*Word*
    rm -R /Library/Automator/*Workbook*
    rm -R '/Library/Automator/Get Parent Presentations of Slides.action'
    rm -R '/Library/Automator/Set Document Settings.action'
    rm -R /Library/Fonts/Microsoft/
    rm -R /Library/Internet Plug-Ins/SharePoint*
    rm -R /Library/LaunchDaemons/com.microsoft.*
    rm -R '/Library/Preferences/com.microsoft.office.licensing.plist'
    rm -R /Library/PrivilegedHelperTools/com.microsoft.*
    OFFICERECEIPTS=$(pkgutil --pkgs=com.microsoft.office.*)
    for ARECEIPT in $OFFICERECEIPTS
    do
        pkgutil --forget $ARECEIPT
    done
anickless
  • April 15, 2016
We have had office 2016 crash so much that we rolled back to office 2011, I hope it works out for you.
  • April 16, 2016
Thats why I am insisting on first removing O2011 and then install O2016 but thats not my decision. The requirement is to coexist both Offices to minimize down time and then remive O2011 once O2016 has been installed. However, Office 2016 we have installed at the start of this year on fresh new machines has been going on OK for the last three months whereas upgrade was never tried before. @anickless did you had issues while upgrading other than licensing issues. I think Composer might help identifying the dir structure for both Offices and then update the 2011 uninstall script accordingly.
