Does anyone have any idea how to disable the "Office Intelligence Services" checkbox in the Office apps "Privacy" preference?
I was able to do so for the Diagnostic Data checkbox.
Thanks, -- M
Thanks, -- M
Best answer by crbeck1
There's a preference for that you can set with a profile.
PII_And_Intelligent_Services_Preference
kFREIntelligenceServicesConsentV2Key
Set both keys to false under each preference domain (com.microsoft.Powerpoint, com.microsoft.Outlook, etc.)
https://macadmins.software/ is a good resource, run by the Office for Mac development team at Microsoft. If you go to that site and click the Preferences button it'll send you to a Google Sheet with all of the different preferences you can set.
