Created a Login Window profile today and the profile installs fine on the client mac but doesn't apply the settings correctly. Firstly it locks out the Require Password settings so a user is not able to change them even though there is no Security payload added in to the profile settings. When you add in the security payload it doesn't allow the user to change them either. The next thing that happens if you remove the security payload is that the Login Window settings display the following text.
OSXConfigurationProfile.com.apple.MCX.loginwindow.jsp is not implemented
Then you can't edit the profile or the settings at all.
Anybody else seen this behaviour.
Using the latest Casper Cloud
