Help needed with EA to gather screensaver "askForPassword" status
  • April 18, 2016
  • 11 replies
  • 48 views
Hello everyone,
I would need a little help from the scripting gurus out there to create an Extension Attribute to gather screensaver's "askForPassword" status in inventory for 10.10.x/10.11.x clients.
The below works for "IdleTime" but not for "askForPassword"... (The domain/default pair of (/Users/username/Library/Preferences/ByHost/com.apple.screensaver, askForPassword) does not exist)
CONSOLE_USER_NAME="$(/usr/bin/stat -f "%Su" /dev/console)"
idleTime=`sudo -u $CONSOLE_USER_NAME defaults -currentHost read com.apple.screensaver idleTime`
echo "<result>$idleTime</result>"
although
defaults read com.apple.screensaver askForPassword
works locally from Terminal and as an ARD unix command sent as the logged user
What am I missing?
Many thanks for your help!
Carlo
bpavlov
  • April 18, 2016
result=$(defaults read /Users/"$CONSOLE_USER_NAME"/Library/Preferences/com.apple.screensaver askForPassword)
bentoms
Forum|alt.badge.img+35
  • April 18, 2016
@carlo.anselmi how is this setting being set, a profile?
bentoms
  • April 18, 2016
The reason I asked the above, is that what @bpavlov posted is valid if you've used defaults to set the settings.
However, if using a profile.. defaults will not pick that up.
As an example, the below is the output for me from @bpavlov's script:
<result>0</result>
But if I look at my Mac I can see it enforced:
defaults is not profiles aware, unless it's an MCX set-once profile (afaik - some testing to be done on this).
However, CFPreferences is:
#!/usr/bin/python
import CoreFoundation
domain = 'com.apple.screensaver'
key = 'askForPassword'
key_value = CoreFoundation.CFPreferencesCopyAppValue(key, domain)
print 'Key Value = ', key_value
key_forced = CoreFoundation.CFPreferencesAppValueIsForced(key, domain)
print 'Key Forced = ', key_forced
This then returns:
Key Value =  True
Key Forced =  True
With the 1st being the value of the key, & the 2nd whether or not it's being enforced via a profile.
  • April 18, 2016
Hello and many thanks for your responses...
@bentoms
Screensaver password/idle time are set with a custom profile, as per this article http://www.johnkitzmiller.com/blog/security-privacy-configuration-profile-bug-in-casper-9-82/
It seems that using @bpavlov suggestion reports correctly in JSS inventory but I'll double check on the client side...
Thank you all again!
bpavlov
  • April 18, 2016
I would go with the recommendation by @bentoms if you're using a configuration profile.
  • April 18, 2016
  • April 19, 2016
Does anyone know if this issue has been corrected in Casper 9.91? Or, is there a way to allow users to pick their own settings for the screensaver in the solution from John Kitzmiller?
jhbush
Forum|alt.badge.img+27
  • April 20, 2016
@macmule interesting my EA returns. I wonder why you get True : True
Key Value =  1
Key Forced =  True
<result>1 : True</result>
bentoms
  • April 21, 2016
@jhbush1973 I probably messed about with something. :)
  • April 22, 2016
@jhbush1973 Yours is probably set as an INT (or a STRING)
@bentoms Yours is probably a BOOL
  • January 6, 2023
Hi there,
I'm trying to update the above to run on Monterey via Python3 but am getting the error:
ModuleNotFoundError: No module named 'CoreFoundation'
I've tried setting the path to the module (which from what I can see is present) and also setting it via find_library but this is not working.
I ideally want this to run without having to install anything else, if possible. If anyone has any suggestions I'd be very grateful.
#!/usr/bin/python3 import os from ctypes.util import find_library pathCoreFoundation = "/System/Library/Frameworks/CoreFoundation.framework/Versions/Current/CoreFoundation" os.path.exists(pathCoreFoundation) CoreFoundation = find_library(pathCoreFoundation) print("The library I am importing is:", CoreFoundation) import CoreFoundation domain = 'com.apple.screensaver' key = 'askForPassword' key_value = CoreFoundation.CFPreferencesCopyAppValue(key, domain) print ('Key Value = ', key_value) key_forced = CoreFoundation.CFPreferencesAppValueIsForced(key, domain) print ('Key Forced = ', key_forced)
