casper 7 and netinstall problem
  • July 16, 2009
  • 5 views
Dear all
since I have Casper 7, the machines I netinstall are unmanaged, so I need to go to the JSS web and enable the management and username/ password
Could it be this something I have to enable somewhere on the web?
thanks in advance
cheers
Carmelo Lopez Portilla
  • July 16, 2009
Check your configuration in the JSS. Under the management section you
need to check "Ensure that Computers Imaged with this Configuration are
managed."
You can also have it create the account for you if its not already in your
image.
Chad
Forum|alt.badge.img+31
  • July 16, 2009
If in your framework settings you have the box checked that says, "Ensure machine is managed," then when you load the JAMF client on to a client machine it will ensure it is managed. Just make sure in your quickadd.pkg it has the proper ssh password for the account that manages casper.
